Borg Warner T56 HELP
Old Feb 15, 2009 | 01:40 PM
Mara man's Avatar
i have a 83 camaro with a 355 roller motor in it. Ive got everything installed and it runs good with the new tranny. My only problem is how to convert the electronic signal to mechanical to fit my gauges that are in it. I like my gauges and don't want to replace them. They make converters but are they any good? Whats the best kind, or what should i do?
Old Feb 15, 2009 | 07:37 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
re: Borg Warner T56 HELP
search...Ill sum it up and say no matter what option you go, you still ger pile drived, as they are all around 300-350.
Old Feb 16, 2009 | 12:28 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
https://www.thirdgen.org/forums/tran...p-cheaper.html
Old Feb 16, 2009 | 07:00 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i bought a cable x box and it's been runnin fine ever since 3-4 years now its not a daily driver but no issuses
Old Feb 16, 2009 | 07:20 AM
rippin ron's Avatar
Car: 91 Camaro RS
Axle/Gears: 4.10
I know you said you don't want to change the gauges but that is the cheapest way. I have the same dilemma. My 91 Camaro has the gear driven speedo rpo. I'm a little better off than you as I can find an electric odometer from another v8 or v6 car and swap it in. All I will need is the Dakota unit to sort out the signals. BTW its Borg Warner or it was, Tremec now makes the t56.
Old Feb 17, 2009 | 01:45 PM
Mara man's Avatar
Re: Borg Warner T56 HELP
One ?... does your spedo bounce at low speeds? cuz i've heard they bounce with that converter. just wanted to make sure it didnt before i purchased it. thanks!
Old Feb 17, 2009 | 02:58 PM
tom86iroc's Avatar
Car: 1986 iroc
i've never really looked but usually a bouncin speedo is usually a worn out gear in the tranny but these are magnetic so like i said if it does it's at really low speeds under 15 i couldnt tell you till i took the car out but i have snow here stillso it'll be awhile
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
