1992 camaro Rear End fitment ?
Car: 92 Camaro RS
Axle/Gears: stock
Hello to ALL, I was wondering what pre years rear will fit my 92 RS?
I have looked all over and cant seem to find this out?
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: 1992 camaro Rear End fitment ?
82-92 will bolt right up no differences except some brake issues with proportioning valves. use the search function
Car: 92 Camaro RS
Axle/Gears: stock
Thanks Jeff, a friend has a 86 or 89 posi rear that he said I could have, I was not sure about all the different years tho. It will not be a dis rear so I sould not have
any brake problems, is this correct?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As mentioned above, your 92 diff is the best you can get without going to something from the aftermarket. If you need a posi, buy a new posi for 28 spline axles and have it installed.
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
db057
Aug 11, 2015 10:11 PM
