TCC question
Old Feb 17, 2009 | 11:16 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
TCC question
is this solenoid normally engaged or normally disengaged?I mean is it powered on or powered off?I mean if i took the battery out would it be engaged? I believe it is normally disengaged and powered on, but i'm not sure. This is for the TH200-C tranny.
Old Feb 18, 2009 | 12:16 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: TCC question
power isn't to the solenoid until told to do so by something-i.e. a computer, toggle switch/ you get the idea.
power is mostly given at cruising speed in high gear for most applications.
MustangBeater20
Oct 29, 2022 09:20 PM
jklein337
Sep 19, 2018 06:23 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
