clunking noise from rear when coming off the freeway?
Old May 24, 2001 | 03:49 AM
89GTA5spd's Avatar
When I come off the freeway after driving for a while (5-10 miles) sometimes I hear a clunk that sounds like it's coming from my differential. 95% of the time i drive on surface streets so it doesn't happen often, but it does happen and worries me that something might be broken. Any help as to what it might be? I am going to put the car up soon to install my alston sfc's so any info on what to look for would be helpful. thanks.
89GTA5spd – Engine: Stock G92 LB9 w/AFPR, JET Fan Switch, Air Foil, Ported Plenum, T.B Coolant by-pass, 180 T-Stat, Flowmaster 3” Cat-back – Transmission: Stock WC T-5, Suspension: Alston SFC’s, Hotchkis STB, Eibach Pro-Kit, 255 BFG Comp T/A’s – Power Adders: NOS TPI #5151 Kit-- Interior/Stereo: Autometer Phantom guages, Sony Deck, RF Subs, Orion amp – Times: (Stock) 1/8 9.78 sec w/ 2.42 sec 60ft, no times w/ S/C or N20 (yet.. )
[This message has been edited by 89GTA5spd (edited May 24, 2001).]
Old May 24, 2001 | 07:36 AM
ede's Avatar
ede
i think i'd be checking the u joints and pulling the rear cover to take a look inside.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 26, 2001 | 03:03 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
Jack the rear of the car and put it in drive to make sure it is the rearend.I have the same prob and I just pulled it out I havn't pulled it apart yet so I don't know what it is exactly it is.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
Old May 27, 2001 | 02:28 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
While you're under there, check your tranny mount and torque arm mount.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
theshackle
Sep 17, 2020 08:26 AM
pimp2303
Jul 27, 2017 02:03 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
