Heres the Deal...
Old May 28, 2001 | 08:47 AM
A2Z87IROC's Avatar
Heres the Deal...
I have a 87 700R4 with 44,000 on it, put in a shift kit, new gaskets and use a 2,000 stall converter. Everything was cool, until I noticed that it is putting fluid through where the dipstick O-ring goes into the transmission. Is it as easy as replacing the rubber O-ring, or do I have too much pressure building up in the transmission, and it's making fluid flow out of that area?
87 IROC z
5.7L TPI 350
TOO MANY MODS TO LIST
"Pardon my noise, its the sound of freedom..."
Old May 28, 2001 | 12:07 PM
Jay727's Avatar
This is a common area for leaks. you shouldn'd have an o-ring on the dipstick it should have a sort of funnel shaped seal, the seals are available at autozone and others. If the dipstick tube has a groove around the end it is the wrong one, a 700R4 tube should taper down at the end. Old turbo350 tubes used o-rings.
I would jack the car up high on the passenger side so the fluid moves away from the hole, clean everything with a rag damp with brake cleaner, apply a small amount of silicone sealer, this will seal it and lubricate it for installation, make sure the tube goes in straight or it will rip the new seal.
blackgold84
Nov 3, 2006 03:12 PM
nickx07
Oct 30, 2006 10:25 PM
nelapse
Oct 25, 2006 01:53 PM
IROC 89
Sep 6, 2006 10:58 PM
breathment
May 6, 2002 09:42 PM
