Where can I get ring ring spacer?
Old May 27, 2001 | 10:45 PM
RICHRAD's Avatar
I have some 10 bolt 7.5 3.42's that I'd like to put in my 2.73 open rear. Is this what I need, a ring spacer? If so, who sells'em and do they come with a set of 10 longer bolts or can I use my 2.73 carrier bolts?
Old May 28, 2001 | 10:06 AM
RICHRAD's Avatar
Come on now guys!
Old May 28, 2001 | 10:48 AM
82camaro's Avatar
Car: 82 camaro SC
I've never seen the spacers for the 7.5 inch ring gear, just the larger ones. But I haven't looked very hard. I take it you don't have the 3.42 carrier. You should have no problem getting a 3 series open carrier from a junk-yard cheap. Or better yet, some type of limited slip/locker. Either way you will need to check how the gears mesh and your backlast, shim as necessary.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 28, 2001 | 10:20 PM
RICHRAD's Avatar
I've just always heard that if you wanna put 3.23s and up on a 2 series carrier you needed a ring spacer. Maybe I'm wrong or it's vise versa?
Old May 29, 2001 | 08:47 PM
RICHRAD's Avatar
Someone!?
Old May 29, 2001 | 09:52 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
richmond sells extra thick conversion rears for your carrier,i don't knowwhere to get a spacer.you could get a 99 dollar posi carrier from slp
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
FormulasOnly
Oct 2, 2015 05:52 PM
