Auto not going into park?
Old May 29, 2001 | 02:13 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
Trans will not go into park. We took the shifter cable off and used the linkage on the trans itself. Linkage will go past Reverse, but when you let go, it will pop back into reverse.
Any ideas on what to look for? Taking tranny apart tonight. Thanks
PS Trans is a TH350 from a 77 Impala/Caprice
Current
86 TA 305 5 speed, hardtop
81 Z28 350, 4 speed, t-roof
99 Ducati 750 Super Sport
Former
85 Z28
94 TA
Old May 29, 2001 | 05:44 PM
transfixleo's Avatar
This may sound stupid and I don't mean it to. When you did this did you try turning the driveshaft? The linkage won't go in if the parking pawl isn't lined up with the tooth in the rear ring gear.
Old May 31, 2001 | 11:20 PM
92rsconvertable's Avatar
I AM HAVING A SIMILAR PROBLEM WITH MY TRANSMISSION I DONT KNOW WHAT IT IS. SOMETIMES IT WONT SHIFT IN TO PARK WHEN I PARK. AND THE NEUTRAL IS ALL MESSED UP. I CAN MOVE THE SHIFTER FROM THE "R" THROUGH THE "N" AND INTO THE "D" AND IT DOESNT CHANGE IT. SOME ONE HELP.
88rscamar0
Sep 23, 2015 09:08 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
Fronzizzle
Sep 8, 2015 12:10 PM
