3rd and 4th trouble
Old Feb 25, 2009 | 05:51 PM
Danus's Avatar
Car: 1989 305 RS Camaro
3rd and 4th trouble
hi, im new to the camaro at the moment mine is a project
its a 1989 305 rs automatic.
but when i drove it 3rd and 4th or overdrive didnt work
the car has been sat around for a year and i dont know the last time it had an fluid change
is it a common problem? easy fixable? or will i need a new box?
Cheers, Dane
Old Feb 26, 2009 | 12:06 AM
Pro Built Automatics's Avatar
Re: 3rd and 4th trouble
It is common to lose the 3-4 clutch pack. first, check the fluid level. Second, check the TV cable for the correct adjustment.
Old Feb 27, 2009 | 04:48 PM
Danus's Avatar
where can i source one of these online?
i have no clue what im shopping for, i have a carbed 305
cheers
Old Mar 1, 2009 | 12:48 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
the 3-4 clutch pack is in the input drum internal to the transmission. To replace the 3-4 clutches, steels, rubber, sealing rings, gaskets, etc. would require removing the transmission and tearing down the trans. You up to it?
I feel this trans isn't for beginners, but you never know. People have walked on the moon right?
Probably wouldn't require so much to get there with this trans but you get the idea.
If you can't fix the trans but can remove it-I'd do that and save some money IMO.
The nice thing about having someone else do the whole job is that they should warranty the labor as well if the trans was to go out within the warranty. Understand? Also they will diag the car correctly (if they are good).
pro is correct, the 3-4's are probably the issue as they hold in third and fourth gear.
Chad Speier
Sep 24, 2015 12:32 PM
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
rsrookie
Sep 5, 2015 07:08 PM
rudolphschenker
Sep 4, 2015 02:41 AM
