What do I need to buy to allow my car to be in 4th at WOT?
Old May 31, 2001 | 07:03 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Cause I'm pissed off at only being able to 1/2 throttle in 4th. Cause I probably could have smoked alot more people on the freeway if I could floor it. So what do i need to buy? I hear I can buy a part out of a Corvette and it will work. THanks.
Chris
91 RS 305 TBI
Eternal Rev
Old May 31, 2001 | 08:33 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I don't know about WOT, but Summit does sell a 700r4 kickdown valve that allows you to cruise at higher speeds in OD.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
Soon to be installed B&M Megashifter
and Exhaust Cut-Out
Old May 31, 2001 | 10:55 PM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
B&M piece does nicely.
86 T/A 5.0
93 Civic 1.6L
13.5 @ 100 mph
Old Jun 1, 2001 | 12:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have the B&M piece, too... easy to install, and works great! The faster you go, the closer the pedal needs to be to the floor to downshift- and it won't kick out at high speeds.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 1, 2001 | 05:43 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You must have taken off the speed governor. My car hits that thing way before the
tranny kicks back down into third though.
Old Jun 1, 2001 | 08:03 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Get the GM b-fix kit, it's cheap, does the same thing and comes with a .500 boost valve and valve body gaskets and a fresh pan gasket.
Just goto a GM parts dealer and order #8673948 or goto http://www.gmpartsdirect.com
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
mustangman65_79
Aug 11, 2015 03:17 PM
MENINBLK
Aug 5, 2015 11:58 PM
