Gearing for street performance - how much is too much? Opinions needed.
Old May 31, 2001 | 09:22 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
Last week I posted a question about running 4.10 gears with a T56. I should have been more specific when providing information. First of all, I'm planning on going with the aftermarket T56, which has steeper ratios:
2.97, 1.94, 1.35, 1.00, 0.84, 0.62
I did some math to figure out what my overall ratios would be with this trans and 4.10 gears. I'm listing the first 3 gears. 4th is obvious.
w/ 4.10's
1st - 12.177
2nd - 7.954
3rd - 5.35
or, if I went with 3.73's
1st - 11.078
2nd - 7.236
3rd - 5.035
Engine is a 360 w/ Edelbrock heads & tpi base, crane cam 216/228 .484/.512 112 ls.
AS&M semi-siamesed runners, 52mm tb, Edelbrock headers, 3" Hooker catback, etc. There's more but those are the basics. Makes power to 6000 rpm, and my goal here is fun street car, it doesn't see much track use.
So, are the 4.10 overall ratios, especially a 12.177 first gear, too much for street use? Would I be better off with 3.73's?
I know some people have run 4.10's with a 700R4, and that trans has a 3.06 1st gear, so overall first gear with that combo would be...about 12.5 - that's steep.
So please tell me what you think, especially if you have run similar gearing. Thanks guys.
Jed
89 Formula 350
[This message has been edited by Jed (edited May 31, 2001).]
Old Jun 1, 2001 | 07:05 PM
Camaroman's Avatar
I'd get the 4:10's
look at the diff. with only going to 3rd gear...almost nothing.
and still have 3 gears to go.
Old Jun 1, 2001 | 08:12 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
I know, I'm just wondering if that first gear would be overkill. That's my main concern.
Old Jun 2, 2001 | 07:13 PM
irocbsa's Avatar
I think that 12.25 is the optimum ratio to shoot for. May be wrong. Of course this number is for track performance.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
Thornburg
Aug 25, 2015 01:46 AM
TreDeClaw
Aug 14, 2015 06:58 PM
