How to tell if u-joint is bad?
Old Jun 3, 2001 | 12:06 PM
Zio's Avatar
Zio
When I put the car in gear it slams into gear pretty hard. I checked the trans mount and it is fine. So how can I tell if the u-joint it bad?
thanks
Tom
Old Jun 3, 2001 | 12:37 PM
RARE-ROC-Z's Avatar
just putting the car into gear wont tell you if the ujoint is gone, and the only way to tell that is to pull the 4 bolts out of the back of the driveshaft and disconnect the driveshaft, but while you have it out anyways you might as well change them, so just go ahead and do it. and it sounds like its your tranny that might make that SLAM, but i might be wrong, i dont know much about trannies. oh well!
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey "Custom" Interior
NOT STOCK, NO WHERE CLOSE!
NEW RED PAINT and WELD PROSTARS.
DAILY DRIVER: 1991 GREY S10 2.5L/5SPD -FOR SALE. leaving for army.
Old Jun 3, 2001 | 02:33 PM
Saywhut's Avatar
if you hear a metal to metal "CLANG" when you put it in gear, that's a good indication they're bad, at least one of them.
A better way to be sure is to slide under the car(on stands) & twist, shake, turn, etc. the driveshaft, while holding the trans yoke for the front, or the differential yoke for the rear. If there's ANY play in either, it's shot. You'll know it when you feel it.
I'm not sure when GM started this, but on some, with the factory U-joints, they're put in with red plastic "locks", if yours has this, you'll need a torch to melt the plastic to get them out.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
