Kick Cable
Old Feb 28, 2009 | 02:06 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Kick Cable
I am looking at purchasing a 88 gta, but it has tranny problems, he says its just a kick cable, can anyone tell me what that is, the problems it causes and price to fix, I have no clue about trannys and the car is set at a good price so I am a little suspicious?
Old Mar 1, 2009 | 01:34 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: Kick Cable
use your instincts, or call cleo. She has a crystal ball.
if someone says a 700r4 has a problem and it is a t.v. cable they might be correct or they might not. Have someone with you that knows how to adjust the t.v. cable and barter if a cable doesn't make a difference. It is easy to get to under the hood and normally has no issues just to let you know. bad 700r4's arent that uncommon and are expensive to fix properly-so obviously the "t.v. needs adjustment" trans needs diaged. properly.
Old Mar 1, 2009 | 05:37 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Kick Cable
yeah I would assume that the trans is bad and the person does not have the money to spend so they are pawning it off on you
tell the guy that your buddy is a trans specialist and he wants to check it out next week.
bluff a little
if the guy says no then presto
if he says yes then take a friend who just learned how to adjust the tv cable
https://www.thirdgen.org/detent
and see what happens
If I was a betting man he wont let a trans guy near the car
Old Mar 1, 2009 | 04:26 PM
Engine: V8 305
Re: Kick Cable
i will do that, he is not from my town so i don't know him really. imo, i don't think he is really old, maybe 20 or so. he only wants like 15-1700 for the car. even with a bad tranny the gta is worth that, but i want to drive it home so my plan is to get him to take it to a garage and tell me what wrong with it before i go so i can get it fixed there without having to rent a trailer and tow it home. thanks for the input guys i will keep you posted.
Old Mar 1, 2009 | 08:31 PM
rocketforme's Avatar
Car: 1989 GTA
Engine: 350 tpi
Re: Kick Cable
I just bought an '89 Gta with tranny problems. My problem was the parking gear didn't work so I eventually had my tranny rebuilt. After the rebuilt the mechanic told me I needed a new Tv detent cable. My cable was a little stretched which would have caused problems to my rebuilt tranny in the future. The kickdown cable cost me about $40. The tpi cable is longer than the carb. if you are looking for one. I would test drive the car to see how it shifts.
Old Mar 1, 2009 | 10:26 PM
Engine: V8 305
Re: Kick Cable
thanks, i am not sure what exactly is wrong with it, i do believe it works and drives but only got 1 or 2 gears but i am not sure. i already sent him an email and i am waiting for a reply
Old Mar 1, 2009 | 10:55 PM
Engine: V8 305
Re: Kick Cable
a pic of the car, although not a good one, i have a bunch more though.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
tattmann
Sep 27, 2015 05:20 PM
