posi trac help
Old Feb 18, 2009 | 09:17 PM
mtz.luis's Avatar
Car: 1989 Chevrolet Camaro Rs
posi trac help
I have a 1989 chevrolet camaro rs, i was wanting to install a posi trac rear end but am having trouble finding the right set up for me. Can any one help me or give me some advise? I was wanting to just swap out the guts in my current diff, what do i need and where can i find it. thanx.
Old Feb 19, 2009 | 06:55 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: posi trac help
Just swap out the complete rear. Less problems then trying to find a Limited Slip parts for yours.
Old Feb 19, 2009 | 07:02 AM
big gear head's Avatar
Re: posi trac help
A new Eaton posi is $475. What gear ratio are you wanting? Do you want to keep the gears that you have now? If you do then all you need is a set of bearings and shims for the posi. If you want to change gears then you need an installation kit and gears.
Old Feb 19, 2009 | 03:03 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: posi trac help
Unless you can determine the condition of seals, bearings etc.,
"just swap out the complete rear" can easily wind up being more expensive
than putting new components in yours.
Case in point.
My starting point was the 2.73-open, drum brakes, which was everything I didn't want.
Picked up a 3.23-posi disc, and started renovation. Both the clutch cones were cracked,
& Eaton indicates this carrier is non-servicable. To gain access to the cones required
removing the ring gear, which has left-handed bolts. (The rest of that story is somewhat
embarassing, so I'll leave it to your imagination.: o)
Suffice to say, for the original cost of $350, I got a housing, axles, & brake mounting
hardware.
And there are some alternatives available in carriers:
http://www.drivetrainspecialists.com/
http://www.ringpinion.com/
http://www.drivetrain.com/
Good luck
Old Feb 19, 2009 | 09:10 PM
mtz.luis's Avatar
Re: posi trac help
ok im convinced on just swapping rear ends but what do you guys recomend i go with?
Old Feb 20, 2009 | 10:37 AM
Re: posi trac help
Editorial correction.
The "clutch cone" reference above is an Auborn product.
I posited the same question to "big gear head", and his response
was an EATON (clutch disc type I assume...) model. Since this
thread has gone in that direction, hopefully he'll weigh in here,
and expand the comments, like pros & cons of the various
options.
kk
Old Feb 20, 2009 | 11:54 AM
Re: posi trac help
The Eaton uses clutch plates that are replacable. There are at least 3 different clutch sets for the Eaton that have different uses. There are also 3 different preload spring sets for them.
The Auburn uses cones that run in a taper in the case. As you turn corners these cones rub against the inside of the taper, which wears on both. When it wears out it is trash. The cones can not be replaced and the case is shot too. Then you get to clean out the housnig and axle tubes because all of that metal is in the bottom of the housing.
Auburn cone and tapered case. Click on picture.
Old Feb 24, 2009 | 09:03 PM
mtz.luis's Avatar
Re: posi trac help
I think i much rather go with my original idea and replace the guts in the diff, rather that replacing the whole rear end. its alot more cost effective in every way. I talked to the guys that distribute and install eaton products but no one was able to help me with what will fit my car. apparently theres nothing that would work with my model car, 89, according to them. any coments on the matter?
Old Feb 24, 2009 | 09:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: posi trac help
You may find useful info in the following sticky:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 25, 2009 | 06:24 AM
Re: posi trac help
I can get you the parts for this. I don't know why nobody was able to help you. It shouldn't be a big deal.
Old Feb 25, 2009 | 07:13 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: posi trac help
Looks alot like a BW posi unit.
Old Feb 25, 2009 | 09:02 AM
Re: posi trac help
The picture is of an early Auburn from a 8 3/4 Chrysler, but the cones and taper are the same for all Auburns.
Old Mar 1, 2009 | 08:02 PM
mtz.luis's Avatar
Re: posi trac help
Where can i buy the parts from or what do i look for? can you give me specific details, i would really appreciate it.
Old Mar 2, 2009 | 09:14 AM
Re: posi trac help
Send me a PM or email and I'll go over everything for you.
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
