2.73-3.73 anything other than speedo out of whack?
Old Jun 5, 2001 | 02:19 PM
MouseCamaro305's Avatar
anything other than the speedo get screwed up or is it just the speedo? are shift points screwed up? lockup points? any remedies for it?
Old Jun 6, 2001 | 12:02 AM
Jay727's Avatar
the shift points are going to be lower, put in lighter governor springs for later shifts below 40mph, use lighter weights for later shifts above 40mph and WOT shifts.
Old Jun 6, 2001 | 03:09 AM
Omar's Avatar
Your converter may lockup sooner. Do it the right way and change it with new speedo gears.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jun 6, 2001 | 10:33 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I went from 2:73's to 3:73's. There should be no other issues. Shift point will not change or anything like that. Just hold on tight, your car will now have some torque!
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
Old Jun 6, 2001 | 12:39 PM
ok thanks a lot guys, yeah lm going to put that gear in right away, otherwise lll be racking up some false miles
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
Ragtop Man
Sep 12, 2015 12:23 AM
