TV Detent cable HELP
Old Mar 3, 2009 | 06:44 PM
rocketforme's Avatar
Car: 1989 GTA
Engine: 350 tpi
I recently rebuilt my transmission and had to replace my tv/detent cable. The part # 10241763 is gm stock for the tpi motor. When I put the cable on the cable came out short according to the mechanic. It wouldn't go WOT. Shifting would slip between gears. The brackets don't look like it could adjust. Why would a stock cable come out short? I bought the cable from Bowtie overdrives and when I called them they said it was the right cable for my motor. Should I just take it to a different mechanic to see why it doesn't fit?
Old Mar 4, 2009 | 07:55 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: TV Detent cable HELP
watch him adjust it
you should push the button and slide the nipple back
then pull to wot
Old Mar 5, 2009 | 12:07 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
you could always get an aftermarket cable that adjusts for length. sounds stupid I know but sometimes it's how the world goes round. BTO is a trans place, and your mechanic is probably an engine mechanic not a trans specialist. What is your solution?
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
