T-56 swap owners
Old Jun 5, 2001 | 12:46 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
T-56 swap owners
I just got a 94Z28 parts car and I plan on installing the T-56 in my 92Z. I have everything except the crosmember which I plan on getting from Steve Spohn. Any tips for me. Plus, I thought the speedo was good to go if you have a electronic one?
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, Accel box & coil, Taylor 409 wires, Fastchips custom chip, MAC sub frame connecters, Lakewood LCA & Adj. Panhard rod, SLP 2500 stall, 3.23 rear gears, 1LE aluminum driveshaft, white face gagues, and NOS!
Old Jun 6, 2001 | 02:37 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Look at the tech article for T56's, it explains it there.
http://www.skulte.com/T56.html
And no, you still need a conversion box since the T56 outputs the speedo signal differently than a thirdgen computer.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 6, 2001 | 08:47 AM
Mark W. Winning's Avatar
Get the Dakota Digital box for the speedo. It will let you calibrate after the swap. Mine actually read 15 mph or so slow.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Jun 6, 2001 | 02:37 PM
Randy92Z's Avatar
Engine: Miniram 383
Does that mean I can adjust my speedo if I change gears too? Right now I have 3.23, when I put in the T-56 I want to install 4.10's. Do they have a web site? Thanks for the help!!
Old Jun 6, 2001 | 07:51 PM
Birmass's Avatar
www.dakotadigital.com
I just ordered one. The cyberdyne sucks. You might also consider just taking your old trans crossmember to a welding shop and asking them to move the center back the required length(around 3-4 inches). It took a welding shop by me not even 30 minutes to do it and it only cost me $20.
Good luck! You'll love it!
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
T56 - SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
All your base are belong to us.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
theurge
Aug 21, 2015 12:46 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
