Rearend is going again!
Old Jun 6, 2001 | 07:07 AM
purpleworm's Avatar
I was driving to work this morning and I noticed the rear end starting to whine again. Last time i split the pinion in 6 places but I caught it before it came apart. It hasn't even been in there for a year and it is going again! I am not even hard on the car! I drive it but now that I am on my 3rd tranny in a year I baby it. No tire spinning!! I jump on it now and then but you have to HAHA. Well I have a rear I just took out of an S10...I should see what it is. What would you guys do? I might break down and by a new posi for it. The big problem is I don't know anywhere that I trust to put a set of gears in.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
Autometer shiftlight tach and B&M mega shifter
One sweet sounding system
Old Jun 6, 2001 | 10:22 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Did you check out this tech article???
https://www.thirdgen.org/newdesign/t...nguprear.shtml
Just because the rear came out of an S10 don't mean squat... same design.
'89 Formula - Thunderchicken - 355 Vette L98/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Jun 6, 2001 | 12:15 PM
sleeper's Avatar
What's the difference between rebuilding yours or the S10's? Either way it's the same.
Gears are not too easy to setup so not just any slack jawed yokel can do it. You need to find a shop that only does gearcases, bearings, axles, etc... Perhaps a shop that does diesel mechanics could do it. Otherwise you may have to go accross the border into the US.
1986 Trans Am
carbed 350 - .30 over with 9.75:1 comp.
+- 315hp/390ft lbs.
700-R4 with 2500 stall
3.27 (ick!) gear
SLP 1 3/4" headers w/MAC catback and cat.
96 5 stars
SFC's, braces, arms, and a bunch more expensive stuff
no timeslips yet
Old Jun 7, 2001 | 06:41 AM
purpleworm's Avatar
Trust me i know what you are talking about. There are nothing but slack jawed morons around here and parts are hard to come by. Last time I got it done the local tranny shop did it because I was an emergency. I am on the search right now for someone that knows how to load everything properly. I asked them if they knew the procedure and they sadi yes of coarse. I didn't beleive a work they said. I know they just stuck them in and didn't use the bluing to check the mesh.
Yes the S-10 rear is the right one and no I am not rebuilding the S-10 rear!!! I just want the gears out of it. I think I might as well find a posi carrier as well. If you break it you might as well make it a bt better.
91 Z28 Camaro
305 TPI
Old Jun 7, 2001 | 06:47 AM
purpleworm's Avatar
That tech article is great! Thanks
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
