t5 to th 350??
Old Mar 4, 2009 | 09:10 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
t5 to th 350??
i got a project car with no transmission and it came stock with a t5 and i was wondering how hard it would be to convert it to a th 350 or should i just get another t5??
Old Mar 5, 2009 | 07:27 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Re: t5 to th 350??
anyone??
Old Mar 7, 2009 | 09:27 PM
bad88_milldawg's Avatar
Car: 1991 Hardtop RS
Engine: 406 Small block
Transmission: TH 350
Axle/Gears: custom fabbed 12 bolt posi, 4:11
Re: t5 to th 350??
Im in the middle of the same swap. I switched to the 700R4 first, but the 700 is kinda weird. So, I made my own aluminum plate to cover the hole in the tunnel, then mounted my aftermarket shifter to the plate. I left the clutch pedal incase I wanted to switch back. Now, if you are for sure going to use the TH 350, then do yourself a favor and go get one with a 9 INCH TAILSHAFT! I tried to use a short tail trans, and ran into the issue of finding a driveshaft that will fit. If you can get an 82-83 driveshaft, then you can use the short tail. If you want to use the 700R4 driveshaft then get the 9 inch. Other than that and you will have to order the Torq arm conversion from B&M or TCI, and you will have to modify the cross member for the trans mount. do all that and your done. Pretty sure Im right?
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
