Transfixleo's TV cable adjustment
Old Jun 8, 2001 | 01:41 PM
Saywhut's Avatar
I saw his post on this, but can't find it now that I'm ready to do it.
Anybody know where it is?
Thanks!
Old Jun 8, 2001 | 03:18 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
You too, huh? I'm not good at posting links, so I'll tell ya where it is. go to page 5 of this forum - it's under the topic "my tranny shifts way too early" by super83z...
KAM
Old Jun 8, 2001 | 03:38 PM
Saywhut's Avatar
Thanks Thunderstick, it works like it should now, better than ever!
And thanks Transfixleo, if you see this!
[This message has been edited by Saywhut (edited June 08, 2001).]
Old Jun 8, 2001 | 10:34 PM
transfixleo's Avatar
You're welcome! I'll make it easy for anyone who's curious:
To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal floored, press the D button and pull the cable back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
