GTO T-56?
Old Mar 6, 2009 | 04:41 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
GTO T-56?
What would it take to make a 2004 GTO T56 and pedals work in my automatic 5.7 GTA? What parts would I need? How much work would it take?
Thanks,
Bill
Old Mar 6, 2009 | 06:38 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: GTO T-56?
The LSx transmissions have longer input shafts to accomodate the hyd slave and the LSx crank offsets. It would bottom out on the SBC pilot/crank before the bellhousing would mate to the block.
Thes LSx transmissions are used with an adaptor plate to mate them to a Muncie or T5 bellhousing, if you have access to a T5 pedal/hyd/bell/clutch setup. You will have to modify your Xmem/Torque-arm/driveshaft to do this though.
I don't think the GTO pedal set will work in the 3rdgen, but I'm not positive.
gixxer92
Apr 12, 2022 12:09 AM
tonys91rs
Oct 10, 2015 03:31 PM
