Part #s for T56/BBC combo
Old Mar 9, 2009 | 10:25 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Alright fellas, i cannot find the part numbers for the swap, i need to know what they are, there were a couple of flywheels for this, i know centerforce was one of them, i am thinking the centerforce might be the same as the small block maybe? Cannot remember, but i need suggestions for a clutch and how long will the T56 last behind a BBC before i need to rebuild it. t has 140k miles on it in my 95 and i will be swapping it out with a T5 so i can use it in the 89. I bought the big block but it is in bad shape, so i am bringing it back to exchange it next weekend.
Old Mar 9, 2009 | 10:50 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Part #s for T56/BBC combo
If you know the Mfg flywheel/clutch you want, they should be able to help you with p/n's.
Depending on the TQ of your BBC, your driving habits, the weight of your car, etc., the T56 may last a few years or a few days... :-/ I've opened up 140K mile T56s that look brand new, and 40K mile ones that are trashed.
If you're concerned about longevity, I'd suggest going through the T56 before installing it, that way there won't be any surprises. You can upgrade it to handle 700+hp while you're in there, just need the time and cash.
(I've got a 800hp viper-spec LT1 T56 on the classifieds if you really want to thrash the BBC)
Old Mar 9, 2009 | 01:14 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The trans should live longer if you choose an aluminum flywheel. The flywheel has to match the crankshaft, as in 2 piece rear main seal or 1 piece, internally balanced or externally. Nearly all BBC flywheels (that aren't for trucks) use an 11" clutch, which, conveniently, is the diameter the T56 uses. Clutch has to match the method of release. The '95 Z28 used a pull-away type clutch, and if you stick with that, then use a higher-rated clutch for a '95 Z28. Those clutch kits cost more, but should be less hassle than trying to convert to a more traditional style of hydraulic release.
Old Mar 9, 2009 | 11:28 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Not sure what manufacturer i want, i need the numbers to see what is available, i think Hayes makes a FW now for the swap too. I have a Dual Friction clutch right now, but i really dont think it is good for over 400 FWHP really. I wish i could convert to the older style clutch setup, but i have been down that road and it is impossible to find a bellhousing that will work, and i already have the T56 setup, so it is cheaper/easier.
Old Mar 10, 2009 | 09:42 AM
85MikeTPI's Avatar
I don't know what you mean by "older style clutch". There is an adaptor plate that will mate a T56 to a T5/Muncie/Saginaw/SFI style bellhousing and allow you to run any bell/clutch/linkage that works with your car and motor combo.
http://www.thegearbox.org/catalog/it...17/4803441.htm
If you want to stick with the LT1 bellhousing and clutch setup, I know McLeod has a street-twin combo for it that will hold 800hp.
Old Mar 10, 2009 | 10:28 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, that will work if i had a LS1 trans, i am going to swap all the hydraulics out and use all the LT1 setup. But yes, by older, i mean the pre 93 camaro/firebird clutch design.
Old Mar 10, 2009 | 12:49 PM
85MikeTPI's Avatar
You only need an LS1 input shaft ($180 new, $50-$75 used). I'm doing a LS1 input shaft conversion right now. Far from impossible.
Old Mar 10, 2009 | 03:12 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, but $$$ is not in the range when i have everything else, plus a new clutch setup
Old Apr 8, 2009 | 07:23 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Still cannot find the PN for the damn flywheel.
Old Apr 8, 2009 | 08:33 PM
85MikeTPI's Avatar
From the McLeod Website:
APPLICATION STEEL ALUM. Teeth Ring OD
993-97 CAM. W/85 DN CRANK PULL 1970-90 454 C/B 460370-3C 560370-3C 153 12.835
1993-97 CAM. W/85 DN CRANK PULL 1991-UP 454 C/B 460370-4C 560370-4C 153 12.835
1993-97 CAM. W/85 DN CRANK PULL CLUTCH 502 C/B 460370-4A 560370-4A 153 12.835
Old Apr 8, 2009 | 08:39 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Thanks man, i wonder what they cost.
Old Apr 8, 2009 | 08:50 PM
85MikeTPI's Avatar
Summit has the Steel ones for $447, and the Alum ones for $707.
The Centerforce 700107 is $390 if your BBC is internal-bal and 2pc rms.
customblackbird
Aug 15, 2021 10:16 PM
ydnar417
Sep 23, 2015 05:57 AM
roysatikas
Sep 22, 2015 08:15 PM
RED85TPI
Brakes
Aug 31, 2015 10:29 AM
theurge
Aug 21, 2015 12:46 PM
