OK, I finally got the transmission back together..
last night. (It's a 4L60E), what do I need to do or look out for when putting the fluid in. I'm pretty sure that the transmission and TC holds 11qts?
I bought a new converter, its a ST3500 from Yank, how much fluid do I need to put into this, as much as I can?
Any thoughts about this I would appreciate it.
1995 Z28 !TB K&N FIPK A4 3.42
Best ET(13.203@106.50)
Taylor 8MM Wires, Autolite 106's, MSD Coil, Mac Header & Y-pipe, Flowmaster Exhaust ,BMR STB,
PowerStop Rotors & Pads, Polished & Ported MAF & LT1 ScanMaster, Power Pulleys, LT4 Hot Cam Kit and Ed Wright Programming. Riding on a set of ZR1 17x9 rims with BFGoodrich Comp T/A tires
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Yea, it holds about 11 qts. and put what you can in the converter. they're slow to take fluid, but it will. don't go dumping all 11 qts. in at once, either. put about 10 in, including what you put in the converter, and then top it off as need be...
KAM
KAM
Polo Z03
Sep 10, 2015 06:43 PM
