B@M shifter install
Old Mar 10, 2009 | 06:07 PM
thirdgen4me's Avatar
B@M shifter install
Is there any modification needed to install a B@M shifter in my 92? Im guessing its just a strait forward install but just checking.
Old Mar 10, 2009 | 06:23 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: B@M shifter install
i just followed the directions, Mine turned out just fine. Alot of people have mixed opinons on the megashifter here, so just be careful on what advice you follow.
Old Mar 10, 2009 | 07:54 PM
Well I have one in my 91 but it came with it so I have never installed one before. I love it so I want one in my 92 also!
Old Mar 11, 2009 | 11:06 AM
fusion116's Avatar
I have on in my 92. Pretty straight foward install. Once you get the Old shifter out, you can bolt the B&M right down. Be careful not to get any kinks in the shift cable and be sure to look @ the diagram to install the shift linkage in the correct place. Otherwise, not a bad install for someone who has never do it before. I'll put sum pics up later if you want. Love my shifter!!!
Old Mar 11, 2009 | 04:26 PM
Thanks guys... I know how to hook the linkage because I had to do it when I did a motor swap in my 91. I was just wondering if I had to modify anything to bolt it in the console. I try to have everything I need when I start a project so I dont have to run to the store.
BewleyBizzIROC
Feb 3, 2020 09:52 AM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
NBrehm
Aug 25, 2015 11:49 PM
mustangman65_79
Aug 13, 2015 07:36 AM
