700R4 to T-5 Questions
Old Mar 11, 2009 | 06:08 PM
Scubaman7337's Avatar
Car: 92 Firebird
Engine: 305 TBI
Hello, I am currently in the process of swapping my 700r4 to a t-5, and have the tranny all installed. However, there are 2 plugs coming to the tranny that do not fit, 1st is a 2 prong connector, and 2nd is a 4 prong connector. Which is the backup plug, and which is the torque plug. Then, should I jump the wires on the torque plug so the car won't stall. And lastly where do I find the speedo plug? This car came with no tranny in it, so I did not take it apart. Any help would be much appreciated. Thanks
-Dan-
Old Mar 13, 2009 | 11:55 AM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
Re: 700R4 to T-5 Questions
The 4 prong plug is for convertor lock up and back up lights, the 2 prong is for the vss. If you do a search you can find a link for the wiring diagram. I have read where some guys have not had any issues running a T5 in an automatic car with a ECM. I have no need for an ECM in my 92
Cacike
Aug 27, 2015 05:10 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
