amsoil tranny fluid?
Old Mar 13, 2009 | 12:01 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
anyone using amsoil atf? im getting my 700r4 rebuilt before i mate it to the new motor and i was thinking of using the amsoil stuff they say it can be used instead of dexron, just wondering if its as good as they say.
https://www.amsoil.com/storefront/atf.aspx
Old Mar 30, 2009 | 03:47 PM
1985blktransam's Avatar
Car: 1985 Firebird Trans Am
Engine: 5.0 Liter Engine
Axle/Gears: 3.08
Re: amsoil tranny fluid?
Hi:
I did run Amsoil in my 85 Trans Am with 700R4 transmission. Issue I had was with leaks. Always a spot under the car. Finally had enough and had the tranmission taken out, drained with converter and put back Dexron III, no more issue with leaks.
I run Amsoil Trans fluid in my 1998 Toyota and 2004 Subaru, no issues at all.
Hope this helps
Rob
Old Mar 30, 2009 | 04:18 PM
Brennan's Avatar
thanks for the reply, so you had a leak with amsoil and none with dexron? are they a different viscosity i wonder? how long was the amsoil in the tranny before you changed it?
Old Mar 30, 2009 | 06:26 PM
Axle/Gears: 3.08
Once I converted back DEXRON III, Drained Transmission and Torque Converter, Leaks Stopped. I had it in for for 6 months or so before I got tired of the leaks plus going back and forth to the mechanic.
Amsoil is an awesome product. I use the Amsoil 5w30 Oil in my Trans Am and my Daily Driver, 98 Toyota Camry. My Camry and Subaru Forrester both converted to Amsoil Synthetic Transmission fluid, no issues at all.
The fuel additive is also great, but Amsoil is getting expensive these days.
The Cooling system in my TA was converted to Evan NPG+ waterless coolant, which I feel the car runs cooler.
Hope this helps
Old Mar 30, 2009 | 07:01 PM
Brennan's Avatar
thanks alot, i have never been disapointed with amsoil. but most company usually have that one crappy product and i just wanted to know this wasn't it lol
Old Mar 30, 2009 | 07:06 PM
Axle/Gears: 3.08
so now, I just use the Dexron Transmission fluid with a Bottle of Lubegard Trans Additive
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
