Rear end noise when you shake car from side to side
Old Mar 14, 2009 | 02:08 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Hi im new to this forum and i got a 1990 firebird and my rear end seems to make a noise when i push it from side to side and i was wondering if maybe it needed bearings i replaced the wheel bearings but that didnt help its a 10 bolt non posi 3.73 gears thanks
Old Mar 14, 2009 | 02:21 PM
big gear head's Avatar
Re: Rear end noise when you shake car from side to side
You are probably hearing the axles moving against the c clips and cross shaft. There is probably some wear on the thrust washers behind he axle gears and on the c clips that has increased the clearances in the rear end. It's not anything to worry about as long as the axles don't move more than 1/8 inch. Have you been doing one wheel burnouts? This will damage the thrust washers and cross shaft.
Old Mar 14, 2009 | 03:38 PM
Car: 1988 camaro
Engine: cammed 3.1
I dont know much history on the car my dad bought it off of a guy 3 years ago and it sat in the back for 4 years and then i bought it off of my dad can the cross shaft and thrust washers be replaced?
Old Mar 14, 2009 | 03:39 PM
Yes, they can be replaced. You might want to just replace the complete differential with a new Eaton posi.
Old Mar 14, 2009 | 03:49 PM
Stephen's Avatar
Car: 87 GTA
I would check the panhard bushings, before tearing into the rearend. At least you can check those without ever turning a wrench. If your skinny enough, you don't even hafta jack the car up!
Old Mar 14, 2009 | 03:51 PM
That's true. I didn't think of that.
Old Mar 14, 2009 | 06:02 PM
Car: 1988 camaro
Engine: cammed 3.1
Thanks for the help guys tomorrow im going to check it out.
Old Mar 17, 2009 | 12:02 PM
Car: 1988 camaro
Engine: cammed 3.1
I had look under the car today and the panhard bushings are worn but would that make the tires vibrate a little when i push the car from side to side?
Old Mar 17, 2009 | 12:34 PM
Stephen's Avatar
Car: 87 GTA
Very well could, by not controlling the sideways movement, induced by steering left/right & road irregularities.
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
