Bent Shift Linkage holder. AND MISSING CLIP
Old Mar 14, 2009 | 05:42 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
HI...Ok on my tranny, where the shiftcable goes, not the linkage adjusting bolt, but the shifter plate that secures the cable with a clip is bent, and the clip is gone.. What are my options.?? Does anyone know where the clip be bought at. . and do i just bend the mounting plate back?
Old Mar 14, 2009 | 07:40 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Bent Shift Linkage holder. AND MISSING CLIP
Your description isn't crystal clear, but lemme first type what I think you have, then what you can do about it. The bracket towards the rear of the driver's side pan rail, that is held by 2 of the pan bolts, is bent. Further, the cable is now moving around relative to this bracket. Is that it? If so, the best solution is a trip to a salvage yard that has third gens. If you're desperate, cut several inches from a wire coat hangar, wrap it around the cable behind the bracket, then you can secure it to either the bent bracket or to the next forward pan bolt. I did this once, just to get home, but it worked well enough to last for 6 months. If this was not helpful, I apologize. Best I can think without a pic of the problem.
Old Mar 14, 2009 | 07:56 PM
a junk yard huh. do they have universal brackets for the TH-700 r4 tranny. and yes you got the problem pinned. two actually. but do if i could buy the bracket and the cable clip at? i want new GM parts not junkyard, thats not practical around here there aint a single third gen for miles and miles. i got the net and the dealership.
Old Mar 14, 2009 | 08:12 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Try to catch the parts counter guy when he's not too busy, and maybe you can find the info for a '92. The older the car, the less likely there's anything in their computers. I'd suggest trying www.hawksthirdgenparts.com. Yes, used, but they'll know exactly the part, no need to hunt a probably-discontinued part number. My dealings with Bruce Hawkins have been good.
Old Mar 14, 2009 | 08:14 PM
i know bruce TOO, i got my coolant rez from him. Hey check this...http://www.bmracing.com/s.nl/it.A/id.275/.f iff i buy that, and then buy the B&m cable, or shifter, am i good??
Old Mar 14, 2009 | 08:33 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I don't know if you can use the B&M cable with your stock shifter, but I do know those brackets will NOT work with your stock cable.
Old Mar 14, 2009 | 10:05 PM
thats chill, ill just get a shifter then, and the bracket. My shifter is sooo not reliable. its junk. belongs at whatever junk yard there is around. i need a reliable shifter and b&m racing built one. Instead of a clip, its nuts. its an investment i was going to get anyways. for 4 years ive been stressing about my car rolling back down the driveway when in park. the crazy thing was, that it did roll back and there was a cop across the street investigating a non licensed tree trimming company.. the parking brake was on, but it slowly creep ed down the driveway, took 5 minutes total time. i had a heart attack. but other than that, i always slam it into park, and double guess the gears. now thats shes(car) dead, ill have time to fix the essentials.
Old Mar 15, 2009 | 07:30 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
B&M makes a version of their Megashifter that fits your center console, but the newer Hammer is so much better to use. Of the 2, a parking valet would have less trouble with the Hammer.
dbrochard
Oct 3, 2015 12:43 PM
dbrochard
Sep 7, 2015 09:41 AM
FormulasOnly
Sep 6, 2015 10:42 AM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
