swapping auto to manual trans
Car: 88 camaro
Engine: 2.8
Transmission: auto
if any one can help me that would be great. i want to put a manual trans in my 88 camaro. i need to know what i need and what i need to do. any help would be apriciated. thank you for your time.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
re: swapping auto to manual trans
Are you going to a V8 at the same time? If not, just search the salvage yards until you find a donor to grab everything from. You'll also need the clutch pedal stuff from under the dash, and the hydraulic release stuff from under the hood.
Car: 88 camaro
Engine: 2.8
Transmission: auto
do i need new cross member and drive shaft as well. do i need a new computer or any thing or can i use all my old stuff. how easy is it to convert it to a manual.
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
i have been wondering this too,
ive looked for a write up or a article and i cant find any yet,
i herd a t5 is week behind a 350, so would i need a t56?
my best route would to get all the parts from a parts car?
is it an easy swap ?
how much would i get charged for this swap at a shop?
input is appreciated thank you.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: swapping auto to manual trans
There are tech articles on this website for both swapping from automatic to manual, and from T5 to T56. They're written for a V8 but should be close enough to help you on a V6.
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rd, 88, auto, automatic, body, camaro, convert, converting, gen, manual, standard, swap, swapping, transmission, transmissions
