T56 Questions in older car
Old Jun 18, 2001 | 11:26 AM
MeanYellowZ's Avatar
k....curious about retrofitting a T56 in my 64 Nova.
First: What spline is a T56 input shaft, 26?
is the distance from where the tranny mounts to the bellhousing to the end of the input shaft gonna be anywhere close to the same as my Saginaw 4 speed?
Any thing else you can tell me about bolting this trans into my mechanical clutch Nova????
Old Jun 19, 2001 | 04:00 PM
kevinc's Avatar
Car: 1982 Z28
Yup, it's 26 spline input shaft.
Distance from bellhousing flat surface to end of input shaft isn't even close. It's a very, very long transmission. Plan $ for a new driveshaft. Denny's in NY is pretty reasonable for custom jobs, just send them measurements and yoke size and they'll hook you up.
Regarding the clutch...I'd go w/ hydraulic. The T56 has no provisions for a Z-bar. The path of least resistance is to get the GM hydraulic setup for $120 complete and mount it to your firewall.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Jun 19, 2001 | 06:39 PM
bigvic's Avatar
If you're mechanically inclined at all or know someone who is and is willing to help, then read this thread:
www.nastyz28.com/ubb/Forum15/HTML/000069.html
This guy modified his t56 to work with a mechanical linkage using his standard flywheel, clutch, and throwout bearing therefore saving money on expensive aftermarket parts. He also tells how he modified his crossmember to work with the t56.
If you have any questions about his install you can email him and he will email you back even though he has since sold the car and changed into a Mopar fan.
BlackphantomZ28
Aug 31, 2015 10:29 AM
jharrison5
Aug 19, 2015 05:53 PM
reiderz iroc
Aug 13, 2015 04:57 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
