stock shift light??
Old Feb 15, 2001 | 09:59 PM
ScreaminDeamin85Z's Avatar
stock shift light??
anyone that has a 5 speed knows whatim talking about. this annoying light that flashes "upshift" at like 2 grand. what can i do about this besides removing the bulb? can i make it wait longer until a different RPm or could i put a resistor in line with the bulb. i dont know if anyone has messed with this before but any ideas or help is appreciated.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC
http://users.argolink.net/bvana
Old Feb 15, 2001 | 10:57 PM
Fastcamaro87's Avatar
i hate that light if you find out anything be sure to let me know...
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Jun 14, 2001 | 11:03 AM
MikeS's Avatar
Having the same problem. Seems to turn on randomly between 2000 and 3000 rpm. Just want to bring this back up to the top, see what anybody knows...
Old Jun 15, 2001 | 01:35 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
It's controlled by the computer. A resistor isn't going to anything better than disconnecting the bulb.
Old Jun 15, 2001 | 02:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You need to get a custom chip specially programmed to change it. I have mine come on at 2300 RPMs to shift while cruising, and 5300 RPMs at wide open throttle. Stock is 1000 RPMs and 4900 RPMs.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 16, 2001 | 10:29 PM
84FTA's Avatar
I made own "chip". Basically it is self contained in the guage cluster (lots of room behind the indivdual metal plates themselves and the back of the plastic housing. I ran a voltage comparator circuit and inbetween is a resistor (soon to be variable), it comes on at about 3,000. It's just a reminder incase I'm not paying attention and start reving high. I'm also on working on a second circuit to active ate a down shift lite (I have an extra guage pod, took the shifter thing out, turned it upsidedown and blacked out the word shift) but that could prove to become rather annoying fast...
I'm going to try and make schematics of it when I get the time
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Jun 19, 2001 | 07:53 PM
OK I hate the light as well, and maybe this can help u.
Here is what my owners manual says about it:
If your vehicle has a manual transmission, there may be a shift light on the instrument panel. This light will show when to upshift for best fuel economy at any acceleration.
When this light is on, shift your transmission to the next higher gear weather, road and traffic conditions permit. For maximum fuel economy, accelerate slowly and shift when the light goes on. When more performance is needed , accelerate as desired and shift when the ligt goes on.
Downshifting one or more gears may be required to keep the engine running smoothly or to maintain satisfactory performance.When downshiftingto a lower gear, the light may come onfor a moment if the accelerator pedal is not released completely. Disregard this light during a downshift.
The onboard computer makes the "SHIFT" light work. This computer knows how fast the engine is going and how hard it is working, how fast the car is going, and how far the accelerator is pressed down. It uses this information 10 times every second to decide if you could get better fuel economy by shifting to the next higher gear.
When the accelerator is released, it is normal for the light to be off.
While accelerating, it is normal for the light to go on, off, and on again if you quickly change the position of the accelerator. In essence, if you change your mind, it will too and it will respond very quickly.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box K&N air filters,TB coolant bypass ,polyurethane tranny and torque arm mounts, K&N oil filter,Mobil 1 synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
