9-bolt rear
Old Jun 20, 2001 | 12:54 PM
Fastcamaro87's Avatar
9-bolt rear
ok my 3.45 9-bolt rear has a tooth missing off the pinion gear , now i need to find a gear set for my rear , new or used, any info would be great, also i need to know if it is possible to put the 9-bolt rear disc brakes on a 10-bolt with drum brakes, because i have a spare 10-bolt rear with 3.73 in it, and if i have to i can put this rear in it, i will also consider trading this rear for the 9-bolt gears or something, any info would be great thanks to all who respond.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box K&N air filters,TB coolant bypass ,polyurethane tranny and torque arm mounts, K&N oil filter,Mobil 1 synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Jun 20, 2001 | 02:42 PM
BTT
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
