Axle issue with 4 gen, movement?
Old Mar 18, 2009 | 02:00 PM
spodeboy's Avatar
Car: 1986 IROC
Engine: 400 SBC bored .060
Transmission: Tremec TKO
I was moving my car when I noticed that if I push on the side of the car, it would move and make a bit of a pop. I got under the car and there is nothing loose that I can find, but I noticed that if I pull on the axle it moves in and out, not very much, but a little, is this normal? Everything is tight, the wheel is tight, the backing plate too, I have no idea if this is correct or not? Any help appreciated
Old Mar 18, 2009 | 02:07 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Axle issue with 4 gen, movement?
It shouldn't move any more than the thickness of a dime.
Old Mar 18, 2009 | 02:41 PM
spodeboy's Avatar
Car: 1986 IROC
That is almost exactly how far it moves, why is that?
Old Mar 18, 2009 | 02:52 PM
Stephen's Avatar
Car: 87 GTA
The axles are held in with c-clips, not bolted in with flanges, so there is some play in the groove that the c-clip fits in. Perfectly normal for SOME play.
Old Mar 18, 2009 | 09:09 PM
big gear head's Avatar
If it has an Auburn differential then the axle end play will increase as the wear increases n the Auburn. It's nothing to worry about. Most GM rear ends have some axle end play.
Old Mar 19, 2009 | 07:50 AM
spodeboy's Avatar
Car: 1986 IROC
Alright, cool thanks all
sailtexas186548
Jan 19, 2016 12:21 PM
Wesly_66
Aug 26, 2015 09:55 PM
red90IROCls1
Aug 25, 2015 06:56 AM
mizz0313
Aug 12, 2015 06:45 AM
