flywheel question
Old Mar 19, 2009 | 03:07 AM
FieroGuy9890's Avatar
Car: 1985 Chevrolet Camaro Z28
Engine: Carbureted 305
Axle/Gears: Stock
flywheel question
Quick question. I've got an 85 z28 with a 5-speed the previous owner blew the original 305 and swapped in a 305 out of a 1990 camaro. He said he replaced the clutch and the flywheel when he did that. The current 305 just got a rod knock so I'm buying a pre-86 (I believe around 1977) 350 to drop in for a performance boost too.
My question is will the flywheel off my 1990 305 work on my pre-86 350? will the clutch?
Thanks alot in advance.
Old Mar 19, 2009 | 05:38 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: flywheel question
No, the later style flywheel won't work. When GM changed to a 1-piece rear main seal for '86, they changed the bolt pattern on the rear of the crank, and added a balance weight to the flywheel.
Old Mar 19, 2009 | 12:30 PM
Axle/Gears: Stock
okay well i found a flywheel for a 2-peice rear main seal would i be able to use the clutch off my 1990 for that flywheel?
Old Apr 2, 2009 | 04:35 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
I am pretty curious about that too.
*EDIT*
I asked the same question in the Engine Swap board and five7kid said that if you got the flywheel off of a 83-85 f-body the clutch will wrk.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
