How Well with a W/C t5 hold up to my 350?
Old Mar 20, 2009 | 09:16 AM
DerfPower509's Avatar
Car: 84 Z28 and a 95 Z28
Engine: Built 350 sixty over
Transmission: W/C T-5
Axle/Gears: 4:56s auburn posi, mosers, girdle
I just finished building my new rear diff with a new auburn posi, 28 spline moser axles, and new richmond 4.56 gears. I have mickey thompson drag radials which explains why im builing a new rear diff and tranny, i destroyed the old 26 spline rear diff. and non W/C t5. I have a 350 putting out around 490 horse and 460 ft/lbs. Im rebuilding a W/C T5 out of a 1990 formula, how well do you think it will hold up? Im thinking not very well but its all i can afford right now. Thanks for the input.
Old Mar 20, 2009 | 09:45 AM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
Re: How Well with a W/C t5 hold up to my 350?
With slicks and your motor good luck you'll need it.
Old Mar 20, 2009 | 09:50 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
It will hold up more than a non-WC T5, but less than a T-56..
Old Mar 21, 2009 | 09:42 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Don't waste your time, get a tremec tko and forget about it.
Old Mar 23, 2009 | 02:17 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
This is a pretty common topic.
Mine lasted until I started running 12's, then it sheared the teeth off third gear.
If you dont race it, and baby it, it'll last a while. But get the coffin ready for it if you race it.
1985Camaro2.8
Apr 21, 2015 06:30 PM
rs89todd
Nov 25, 2012 12:45 PM
dpmalibu
Aug 19, 2011 12:00 AM
kickass92z
Feb 15, 2007 08:01 PM
