My 89 Camaro shuts off when it hits 5mph
Old Mar 22, 2009 | 01:20 AM
coyote452002's Avatar
I turn on my 89 Camaro (TPI, 350, 700r4 trans,) when I put it in gear it runs only till it hits around 5mph, then it shuts of; it turns on again with no problem and stays on without a problem i can leave it on for hours. I have rebuilt the trans and bought a new torque converter. Can someone help!!
Old Mar 22, 2009 | 01:47 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: My 89 Camaro shuts off when it hits 5mph
I really don't have an answer for you, just a guess. I don't even know if the top speed is limited on an '89, but maybe a problem with that, or the VSS.
Old Mar 22, 2009 | 08:25 AM
87InRecovery's Avatar
Car: '87 Camaro Sport
Engine: 3.4L w/headers, Crower & Hypertech
Transmission: 700R4, B&M Shift Kit
Axle/Gears: ?
Well, I have a 2.8L and it has the oil pressure sensor on it. If oil pressure drops below normal, it is suppose to shut off fuel pump in order to save the engine. Not sure if this is the case for your engine. Can you rev it up in "park"?
Old Mar 22, 2009 | 09:19 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Also check the grounds that should be bolted to the back of Both heads. There should be 2 or 3 grounds on both heads. If these are not on/tight, most of your sensors,injectors,ignition,etc will fail with just a little engine load. (At idle, they can find grounds through various paths, but they can't sustain them under load)
Old Mar 22, 2009 | 10:39 AM
The engines revs just fine when its in park
Old Mar 27, 2009 | 07:27 PM
327Chevy's Avatar
This is a longshot. Have you been doing your own proms? There was a "joke" in one of the calibrations posted in the "come-in-for-a-free-tune" thread. It involved a speed limiter killing the engine at very low vehicle speeds.
92camaroJoe
Jul 29, 2023 07:57 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
