Is this normal
Is this normal
At 1500RPM's in Drive & OD the transmission
seems to be seaching for a gear. I have a 2400 stall Torque converter. Above and below
this everything is find is this Normal??
Car: 82 camaro SC
Sounds like the TC is locking and unlocking, you may want a manual switch with that higher than stock stall converter.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
Mine does that too and I was thinking of buying a handle with a button on it. I have the console megashifther and you could hook up a latch relay off the button. You could then hook the relay to the lockup button on the brake pedal. One push would let the converter lock like usual and one more push would make it so it wouldn't lock up. People say that it increases heat not having the converter locked but what is happening with all that locking and un locking. Stress on the whole drive train and heat from the shifting!!
Linson
Oct 1, 2015 09:50 PM
