What does this wire do?
Old Jun 25, 2001 | 09:46 PM
86IROCZ's Avatar
I am in the process of converting my car from a auto to a t-5. I know that the purple and yellow wires are for the park/neutral switch and I have them hooked up to the clutch switch. I know the green and blue wires are for backup lights. There are two more wires that the book (haynes and chilton) says are the park/neutral switch. I looked at the diagrams and switch is wired to the ECM (closed when the car is in park or neutral). My question is what does the ECM do with this signal? Does it change the way the engine runs when the car is in park? Does any one know what will happen if I just don't hook up those wires?
Old Jun 25, 2001 | 10:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I believe the ECM raises the idle speed when the transmission is in park or neutral.
Old Jun 27, 2001 | 02:26 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
As I recall one of those wires is black with a white stripe. It was hooked up to the NSS. It will need to be wired to the emergency brake. Otherwise you will need to push on the clutch in order to open the hatch.
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Jun 27, 2001 | 02:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The regular park/neutral wires (yellow and purple?) should control the hatch release.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
