Installing TransGo ...Need Advice on "Stick" or "Auto"
Old Jun 27, 2001 | 02:07 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I wanted to see if any of you had any good advice on wich way to go when Installing the kit. The "Stick" or "Auto" option????
I would think that the Stick would be really fun but what is more pratical for racing??
also is there anything else I need to know when installing that Might help
thanks for any info
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
[This message has been edited by Hecubus (edited June 27, 2001).]
Old Jun 27, 2001 | 04:52 AM
transfixleo's Avatar
Go with the auto setup. For WOT racing it will act the same (as long as you aren't trying got short shift it). Manual ****ing an Auto isn't like driving a standard. It get's old quick.
As for suggestions, go conservative on hole sizes, primarily the 1-2 feed. I am doing a performance buildup for a '91 IROC right now and I used the smallest hole size. It will still give me a short shift but I am also looking for longevity. The Sun Shells like to break on these and the bang 1-2 shift will really help that. I always replace the Shell with a new GM one. As a matter of fact, on this one the Shell had a hairline crack in it so it is a good thing I am replacing it. Most people wouldn't have noticed it.
Check the accumulator pistons closely as they like to wear the hole in the center oblong. In fact you may want to just get new ones. Don't second guess the designer of the kit. If you really have a high power (racing) engine then go to a larger TV Boost Valve than specified but otherwise use what they say.
[This message has been edited by transfixleo (edited June 27, 2001).]
Old Jun 27, 2001 | 07:00 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Thanks that will help
Anyone else???
Hecubus
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
Leggman1
Aug 6, 2015 04:15 AM
