4th gen 5-speed tranny
what kind of tranny did the 4th gens have? i know the auto was 700r-4, and the 6-speed was the t-56, but what about the 5 speeds in the 6 cylinders. how strong are these 5 speeds? could i replace a 700r-4 in a 3rd gen with this tranny? direct fit? same size as the 700r-4?
Car: 87 GTA
Re: 4th gen 5-speed tranny
If you want a manual 5-speed, why not just use a 3rd gen V8 T5?
I'd be concerned about a tranny designed for a V6, being put behind a V8.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You'll have the same problem as trying to put a thirdgen V6 T5 behind a V8. Its not recommended due to the differences and the weakness of the tranny.
this forum for the info.
this forum for the info. Re: 4th gen 5-speed tranny
well strength was my whole issue. i have no idea about the strengthness of the v-6 5 speed thats why i asked. i know that the t-5 in a nutshell is pretty much as strong as using string as a tow strapso thats why i asked. what is the model number of the 5 speed trans?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
it's a T5, but the 4th gens used the Ford input shaft setup. Weird, huh? But true.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Further, there are no cheap, strong manual transmissions for us. In fact, transmissions are the biggest problem for any V8 third gen.
Car: 87 GTA
FWIW.......
Despite GM not putting T5s behind the 350s, I've plenty of people who have swapped WC T5s in behind their 350s.....And the T5s survived without problems.
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Thornburg
Aug 25, 2015 01:46 AM
