Trans filter seal stuck in shaft
Old Mar 24, 2009 | 08:16 PM
19Pontiac88's Avatar
Car: '88 Firebird Formula
Engine: 355 TBI
Axle/Gears: 10 bolt
So I'm changing the fluid on my 700-r4, and I got the filter out to put the new one in (it more like fell out) and the seal wasn't on it. I tried to pull it down with my finger, but it only came down a little, and now it won't budge. Thing is, it's made of some very hard rubber, so I can't cut it or manipulate it much at all. Think I should just take the seal off the new filter and put it on, or do I really have to get the old one out?
Old Mar 25, 2009 | 07:33 PM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Re: Trans filter seal stuck in shaft
Your choice...it can't fall out with the pan on.
..If you want the old one out take a small straight screwdriver and
tap it up in between the seal and the housing.
Or use a cotter pin extractor (looks like a screw driver with a bent over
end)
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
formula_novice
Aug 18, 2015 08:48 PM
