Swap A 5 speed for automatic
Old Mar 25, 2009 | 11:33 PM
arozr600's Avatar
I have a 91 GTA with a 305 in it with a 700r4. I want to swap it out with a 5 speed to make it a little more fun to drive. I was wondering if anyone knew how hard it is? If any company makes a kit that comes with the pedals slave cylinder ect. And if there is anything else i would need to change with it, such as drive shaft, crossmember, torque arm ect. Any help would be greatttly appreciated. Thanks alot guys in advance
Old Mar 26, 2009 | 12:45 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Swap A 5 speed for automatic
there is a tech article explaning the swap, the only thing he doesnt cover is speedo. basically you have an electronic (vss) set up. if you get the trans from an older car you will need to get the vss. there is a sticky on the trans and drivetrain forum that will show you how to identify a wc from a nwc.
Old Mar 26, 2009 | 11:25 PM
arozr600's Avatar
thanks man i apreciate the help nd not being pissed nd tellin me to search right away i tried searching before but ill deff check out the sticky. thanks aga8in man
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Keith5
Aug 27, 2015 04:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
