converter bolts
Old Jun 30, 2001 | 10:16 PM
Jimmy_CFH's Avatar
converter bolts
I recently had a little problem with my converter. I somehow lost all 3 bolts out of the converter. I was driving down the road and then all of a sudden the tranny was whinning loud and I wan't going anywhere. After I bought some new bolts, I noticed that one of the bolts stripped out the threads in the converter. I was tricked into buying a B&M TorkMaster converter (DON'T BUY ONE, THEY SUCK HARDCORE). Anyways, I was wondering if I could run on only 2 bolts? Would it damage the oil pump? I really don't want to drop the tranny. It's a built-up 350 backed up by a THM-350. This is all in my truck (77, 1/2 ton), so the tranny has the extra clutch packs and the motor is a nice 4-bolt. Thanks.
Old Jun 30, 2001 | 10:31 PM
82camaro's Avatar
Car: 82 camaro SC
Running just two, you risk shearing them off. Instead of the bolts holding 33 percent of the torque applied, they must hold 50 percent.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jun 30, 2001 | 10:34 PM
Jimmy_CFH's Avatar
The bolts are hardened ARP bolts. And they're covered in locktight. I figure I went a while with only 1 bolt... I just don't want to catch one in the leg or crotch.
Old Jul 1, 2001 | 11:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's your life. Once something like that (serious personal injury) is done, it can't be undone. I wouldn't drive a car like that. My life and limb is valuable enough to me that it's worth an afternoon's work to avoid endangering myself. That's just MHO, others may feel differently.
ICON Motorsports
Old Jul 1, 2001 | 10:56 PM
82camaro's Avatar
Car: 82 camaro SC
I doubt you went very far at all with one bolt.
82camaro
1992 Trans Am
May 10, 2023 07:19 PM
1984HO
Mar 19, 2021 11:59 AM
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
