Transmission End Play
Old Jul 1, 2001 | 04:52 PM
Chris 611's Avatar
I hear two clunks from the underside of my '91 Formula 350 whenever I go from Drive to reverse or reverse to drive. It sounds like one is right under the seat and one is farther towards the rear of the car. I pulled the drive shaft and the universal joints don't feel like they have any play. They pivot alright, not perfect. However I noticed that the splined shaft coming out of the rear of the transmission has quite a bit of play in it. Is this right? Its probably .06". Is this the source of my clunk or can the U-joints be casuing all that noise? Any help would be greatly appreciated. Thanks.
Old Jul 3, 2001 | 07:51 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Check your tranny mount. Stick a prybar or breaker bar in between the x-member and trans and see if you could lift it off the mount.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mizz0313
Aug 12, 2015 06:45 AM
