Is anyone using (or have used) the "stick shift" option "TransGo kit" on a 700r4???
SubscribeI wanted to know how responsive it is??
I dont think I will get tired of it as I dont drive it verry often
Do you have anyreason for not do that option???
Thanks for any info
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Thanks for any info
Hecubus
Anyone ever even heard anything [good/Bad]about it ???
I think I'm gonna give it a try
anything will help thanks
Hecubus
Hecubus
I have built hundreds of 700R4's and have not built the "stick", mainly because of the weak points in the 700R4. If you make a wrong gear start more than a couple of times it is possible to do damage to the unit. Stick with the automatic and you will have less problems. If you choose to do the stick, make sure the TV cable adjustment is absolutely right on (use transfixleos setup on the TV cable) Follow the directions closely. Remember when you downshift, make sure you give it gas to bring up the "R"'s too match the rpm of the next gear!
Hope This Helps!!!
Hope This Helps!!!
Can't think of a good reason TO use the stick shift option. If you want to hold on for later shifts you can do this with the full auto setting.
well Good point
I think I'll just go with Full Auto
thanks for the help guys
Hecubus
Hecubus
