Help, Trans Not Shifting Right?
Old Jul 5, 2001 | 06:39 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I just had the trans rebuilt with a manual valve body, when I shift from 1-2 at high RPM 3500 or higher the trans drags for about a second before going into second, if I just take off normally the trans shifts firm. I feel this is seriously hurting my 1/4 time, I G-Teched it and ran a best of 15.86 @93mph, I feel I should be faster than this. Well here comes my question, I am having a set of gears installed in a couple of weeks, and I was going to have the guy install a vette servo and .500 boost valve, would this firm up my 1-2 shift or should I pay him extra to take a look inside the tranny to see if anything is wrong, considering I did just get it rebuilt. I just can't stand knowing my car is so slow.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
Old Jul 5, 2001 | 08:40 PM
Jay 727's Avatar
It sounds like one of the clutch packs is either too tight or too loose (clearance). The boost valve will help firm up the manual 1-2 shift and the servo will firm it up in automatic and manual but not until you get your other problem fixed.
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
