T.V. cable adjustment
Old Jul 6, 2001 | 09:42 PM
84zeddd's Avatar
When changing over from Qjet to holley my
mechanic fabricated a home made cable with
a set screw to adjust the T.V. cable.Can anyone tell me how to set-up the tension?Is it possible to bring the shift points up to
5200-5500 by adjusting the cable?
Thanks guys
Old Jul 7, 2001 | 12:11 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
From my knowledge of the tv cable, you shouldn't adjust it to get the tranny to shift later, the cable controls line pressure in the tranny and by adjusting it improperly can damage a tranny.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
Old Jul 7, 2001 | 12:14 AM
Car: 99 Formula
Axle/Gears: 342
Just a quick question, when you had the Holley put on you did get a Non CC Distributor, right, I made this mistake and the carb was constantly dumping fuel (10mpg).
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
Old Jul 8, 2001 | 04:48 AM
transfixleo's Avatar
With a stock tranny and correct TV geometry there is only one correct setting and that is with the engine at WOT the TV cable must be at WOT. To get higher WOT shift points requires a different governor.
88SS6SPEED
Nov 11, 2015 07:05 AM
WejaZ28
Oct 3, 2015 07:38 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
