help with my trans!!!!!!
Old Mar 31, 2009 | 08:24 AM
camarojuggalo's Avatar
Car: 1987 Iroc-z
Axle/Gears: 3.73 posi
Im pretty sure this has been up here but i cant really find what im looking for can i use a trans that is from a later iroc on my 86 and how can i convert the electric gearing to the cable drive that my car is.... i cant find the info any where do i just unbolt the plug on the side or is there more than that
Old Apr 1, 2009 | 01:01 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: help with my trans!!!!!!
yes you can
use a puller to remove the reluctor ring (the pressed on metal speedo gear)
buy or use your old clip and plastic speedo gear
the output shaft should have a hole for the clip even though it had a metal reluctor.
Old Apr 1, 2009 | 10:53 AM
Car: 1987 Iroc-z
thanks will try this weekend
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
