Tranny Lines
Transmission: 4L80E/4L80E
JB Weld won't stick well to an oily surface. If you can absolutely clean that line of oil, roughen up the surface a bit, you might get it to work.
An easier solution would be to get a splice fitting, cut the line on each side of the hole, and install the fitting. Another possibility is a piece of 3/8" high pressure oil hose clamped on as a splice.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
It would probably work, but why take the
risk of frying your tranny if the JB Weld
were to fall off? Use a 5/16" compression
fitting to splice the line or replace the line. I usually make mine from a 5/16" x 60"
brake line. If you prefer, buy a used one from a salvage yard. Just make sure the lines
don't rub on something such as the edge of
your oil pan.
your oil pan.
