Question about manual transmissions
Old Jul 9, 2001 | 12:27 AM
StCr19's Avatar
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
Ok, in an automatic transmission set up it goes Crankshaft>flywheel>torque converter>transmission.
What is the drivetrain with a manual? Crank, flywheel, clutch, transmission? And what is a flexplate?
Old Jul 9, 2001 | 12:34 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
crank-pilot bushing-flywheel-clutch-pressure plate-t/o bearing-clutch fork-bellhousing-tranny. Flexplate is what is used with an automatic and the torque convertor bolts onto that, and the flexplate bolts to the crank.
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
Vintageracer
Jan 10, 2020 05:33 PM
formula1lle
Jan 29, 2016 10:56 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
