is my rear end going out?
Old Jul 10, 2001 | 12:07 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
ok my car used to only spin one tire when i would do a brake torque....and at cruise night my car was catching posi all night long and i tired again today and it is still doing it......my bro says that my rear end is going out...he said that the spider gear is getting old and is sticking and it means my rear end is gonna go out soon......but my car still only spins one tire around corners and stuff like that......is it going out or am i just getting lucky that my car is catching posi so much??
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
best E.T. (dont laugh) 15.997 @86.04mph
http://www.geocities.com/K_towngangsta
Old Jul 10, 2001 | 10:10 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
does anyone know?
i really hope my bro is wrong
Old Jul 10, 2001 | 05:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Probably luck, although you might have a wee bit more weight on the right side that's helping traction.
If you haven't done so recently, you might consider pulling the cover from the rear and looking things over anyway. If you haven't changed the gear lube, now's a good time to do so. If you find chunks & sparklies in there, you know your brother is right, but you don't necessarily have to tell him...
MY brother had a '66 Impala SS 327 4-speed in the early '70's that would pull posi's. I know for a fact it was open, and that rear was still going strong when he sold that car (I was overseas when he did, could have strangled him).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
